Infuse not selecting correct audio track even when Jellyfin does
i have an issue with infuse not auto selecting the correct audio track on playback.
Jellyfin Direct mode.
example
video file has 2 audio tracks - track 1 Portuguese, track 2 English
Jellyfin correctly makes track 2 the default audio track based on the user preferences (language set to English), however in Infuse it starts playback on track 1 Portuguese and i have to then manually change the audio track to English.
in Infuse > Settings > Language i have Audio and Subtitles set to Auto, should this not be enough for it to correctly select the audio track based on what Jellyfin already presents?
Sounds like audio tracks are either both default or possibly forced, depending on files format mkv or mp4 ect, the easiest thing to do is to run movie file through some remux software, I use mkv tool nix, but there are a few softwares that work, that are quick, I expect your find the file has forced audio selected, which is why it keeps reverting.
no, this isn’t a file issue.
jellyfin itself selects the correct audio language as it knows the user is set to use English (even though english isn’t track 1)
but infuse it ignored that and defaults to playing track 1 which isn’t english.
neither audio tracks are set to forced.
It looks like, in infuse > language settings, auto isn’t able to work out what language to pick, but specifically setting it to English means playback selects the correct audio track.
Infuse will always select track with first default audio track, when it’s set to auto, I remux all files I add these days, it’s handy for keeping true hd atmos, and adding e-jock atmos 5.1 tracks, and changing the 5.1 atmos track to default and the truehd to not default, so infuses fires up supported atmos file, without selection.
Auto should auto pick the correct audio track based on the user, and not override what jellyfin present as the audio track.
i shouldn’t have to specifically set a language in the infuse settings for it to play the correct audio track.
