Infuse not reflecting my deletions
I have a similar (but different) issue to my other forum post about deletion behaviour on ipad…
If I delete a movie that is stored locally on my ipad (through the Files app) and then refresh Infuse, it still ‘sees’ that deleted movie. I can re-fresh and re-sync many times but it never disappears. I can delete movies through Infuse interface and this works but then that deleted movie fills up the System Data portion of the ipad (which is, currently, a black hole of lost data that is irrecoverable without restoring my ipad which isn’t an option). So, at present, i’m unable to free up usable space on my ipad from deleting local files. I wanted to test removing the movies via the Files app to see if this fixed the issue but Infuse doesn’t want to acknowledge that the file has been removed.
Is this file appearing in the top ‘Watching’ row? If so, you can long-press on the title’s image and select the ‘Remove from Watching’ option to remove it.
Thank you James,
When I long press the movie poster the only option I have is ‘Add to Watching’.
As a side note - I tried with a different movie and it worked as expected but some movies seem ‘stubborn’.
cheers,
