Recently I have been noticing that Infuse is not recalling the playback progress for movies or tv shows.
The movies I am watching also disappear from the home screen and even when I find them again and start to play them, it plays from the beginning. This has been happening a lot
How are you connecting to your server? SMB, FTP, DLNA, Etc?
Also, you may want to check the setting in Infuse for “Resume Playback”.
I am connecting to a Google drive
Did you do this?
Yes it is set to “Ask”
Are. you switching between devices, or always using the same device?
Does this affect all files, or just some?
Are you seeing the correct ‘Resume XX:XX’ text Infuse before playing, or is this missing?
