I am new, so forgive my ignorance. I have integrated Plex with Infuse and I wondered what the Infuse settings should be for Metadata ? If I am using Plex to collect the metadata, should the Infuse metadata setting be set to off ?
In fact do any of the Infuse setting have any effect if the integrated Plex is being used. ?
Is there any general information anywhere for using Plex with Infuse Pro ?
Thanks.
The metadata settings in Infuse will not have any effect when streaming from Plex, as Infuse will always use the metadata present in Plex.
The one exception to this is if you are connecting to Plex via DLNA, instead of thew new integrated ‘Connect to Plex’ option.
Can I delete items from my Apple TV using the Plex Ingegration ? I had the option to do this yesterday, but the delete tab has gone today
