infuse is all of a sudden merging the battlestar galactica 2003 mini series with the 2004 series and when you update the metadata on one it updates the other i cant get them to seperate, the files are named using tmdb as the meta source so they look like this
Battlestar Galactica (2003) S01E01 - Part 1 for the mini series
Battlestar Galactica (2004) S01E01 - 33 for the main series
i actually changed it to that and a couple of other ways, but i have found the issue, when i download the eps from my plex server infuse renames them both battlestar galactica s1e1 with out the year but if i transfer the files over using usb it works correctly and each is matched properly.
so the issue is for some reason plex is nolonger keeping the year when it renames the files during syncing
I don’t know if it’s Plex or infuse but the files have always been renamed everytime I’ve synced from the server, on the server they are named using the Plex naming convention so like series year s01e01 episode name, but when I download them to infuse they get renamed series s1-ep1.
Hopefully when they introduce better Plex integration it will help with this until I guess I’ll just use iTunes to transfer any problematic ones
ok so it is a plex problem, plex for some bloody reason names battlestar galactica (1978), battlestar galactica (2003) and battlestar galactica (2004) as battlestar galactica without a year so no matter how i name the files they will all be called battlestar galactica when ever i download to infuse
