Infuse Media Library Sync Failure with iCloud
Hello everyone,
I recently encountered some issues while using Infuse and would like to explain the situation.
  1. I am using an Apple TV 4K (1st generation) with Infuse Pro version 7.7.7 (4846), located in mainland China, and utilizing the Stash proxy software.
  2. When I refresh the media library, after some time, it consistently shows: “Sync with iCloud (Recently: Failed)”. This happens regardless of whether the proxy software is enabled or not.
Request: Is there a solution to this problem?
This usually means there is an issue with the iCloud account being used.
You may try signing out of iCloud on the device and then signing back in, to see if this helps.
