Seemingly having some trouble with Infuse while it’s linked through Plex on the newest Apple TV it seems to be using Max bandwidth about 900mbps for every file causing other people who share my plex server to suffer buffering any ideas why infuse is using so much bandwidth about 9 times the bandwidth then what plex does if I just stream it from plex directly
It sounds like it’s doing the read ahead cache with the streaming cache setting set to Auto. You can set it to Memory only which will not use the disk space, only memory or you can set it to legacy and not have a read ahead buffer at all the way I understand it.
Thank you so much total lifesaver back to totally normal bandwidth now thanks times a million
