Infuse library remain empty when using Google Drive (shared with me)
Hi there,
I am using infuse 7.4.7 on iOS, iPadOS and tvOS, with Google Drive setup.
I found that the app won’t fetch library when I add folders under “shared with me” into favourite, the app only fetch content under folders “Team drive”. May I ask if it is expected behaviour? I have checked support article “Streaming From Cloud Services” and it haven’t mentioned. Thank you.
Step to reproduce:
  1. Go to Settings in infuse app
  2. Add Files > Add Google Drive > Login Google Drive account
  3. Go to Google Drive account > “Shared with me” > Add any folders with media files in it into favourite
  4. Go to Settings > Library > Click “Scan for Changes”
Actual Behaviour:
The app report fetching finished in seconds without any media being recognised.
Expected Behaviour:
The app should fetch all the media in the favourited folders and show up on the library page.
Remarks:
When I repeat step 3 with adding folders under “Team Drive”, Media are fetched and shown on the library page.
Thanks for your time.
Patrick
Are you able to browse the files contained in the ‘Shared with Me folder’ if you access them directly, via the favorite found in the Files tab (or on the Home Screen if you are using the ATV)?
Yes, I can access those media files under “shared with me”, those media will show up when I favourited the exact folder.
FYI. My media folder/ file architect are as follow:
Google Drive/
Shared with me/
Movie/ Pulp Fiction (1994)/ Pulp Fiction (1994).mkv
Drama/ Show Name/ Season 01/ Show Name - S01E02.mkv
Google Drive/
Team Drive/
I have manager access on both folders under “share with me” and “team drive”.
Thanks.
Patrick
