Infuse is abusing public ntp servers
Hello,
I have been monitoring my network traffic for some time and noticed that infuse is constantly querying public ntp servers for correct time. This is creating additional unnecessary overhead on public NTP servers. Applications on apple tv or on ios in general should not do that as they already have correct time on OS itself, which is also in sync with ntp. If you still insist on using NTP, even though you should not, please consider this: http://www.pool.ntp.org/vendors.html
Which version of Infuse are you using?
A number of improvements in this area were added in 5.2.1 which was released in January.
I am using Infuse Pro 5.3.1
We’d like to look into your particular case, so if you have a chance would you mind sending in a report from your device?
sure,
code is DDEST
Thanks. We’ll take a look. :wink:
