Hello, any video I play produced juddering and dropped frames on any format and resolution used, when panning or movement it skips frames. Clearing cache solves it for 10 minutes then it skips frames again.
Which model iPhone do you have and which version of iOS?
Do you have auto-brightness or low power options enabled?
Can you send in a report from your device and post the code it gives you here?
