I’m testing Remux as a Jellyfin-compatible server with Infuse 8.5.2.
The setup works up to the point where Infuse starts playback, but the video then loads indefinitely.
What I’ve confirmed:
- Remux successfully finds streams from the configured Stremio/AIOStreams add-on.
- Remux reports playback starting with client=Infuse-Direct.
- Playback method is reported as DirectStream.
- No transcoding is being used.
- The exact same media URL returned by the add-on plays correctly when opened directly in Infuse.
- The same URL also plays correctly in VLC.
- The issue occurs on both iPad and Apple TV.
- Infuse is updated to version 8.5.2.
So the stream itself is valid and Infuse can decode/play it, but playback hangs when the same stream is handed to Infuse through Remux’s Jellyfin-compatible interface.
Has anyone seen similar behavior with Jellyfin-compatible servers, HTTP redirect/direct-stream URLs, or Remux specifically?
Is there anything Infuse expects from the Jellyfin DirectStream response that could cause an otherwise valid external media URL to hang indefinitely?
I’m happy to provide sanitized logs or additional technical details if useful.
Log code: XSETE
