Infuse grabbing wrong metadata for my home movies
Hi - Next to the maps on my server where I keep my Hollywood movies, I also have a map which is reserved for the movies about my grandchildren a.s.o.
Unfortunately, Infuse also searches through the online database for these home movies. So there is a movie which we have called ‘Hello World’, about one of the kids. But Infuse thinks this is a movie which features Christina Aguilera (which is definitely not the case ;-), so it produces wrong metadata and illustrations.
Is there a way to keep certain maps ‘hidden’, i.o.w. can I tell Infuse not to do its best for this specific folder?
Thanks for your help!
Long press on the folder and select ‘Use local Metadata’.
Thank you - That was simple! :wink:
