Infuse for iOS - Rememedy for Accidentally Removing Shares
I can’t tell you how many times I have accidentally removed my share from the Settings > Library window by accidentally tapping on the share instead of “Scan for Changes”, which is right below the share(s). I’ll hurry and tap it to turn it back on, but it takes a while to re-sync with the metadata, especially since it’s a larger library. If I wasn’t storing my metadata in iCloud, it would take much longer. Anyway, can we get a confirmation prompt, or even replace the tapping gesture functionality with a swipe gesture, please? Maybe consider putting more space between the shares and the “Scan for Changes” button. Thanks.
So much this.
There’s already an open issue for this, with some modicum of support, so might as well centralize support: [BUG] Make it more difficult to wipe out indexed libraries / favorites
