Hello folks,
Quite new to Infuse, trying to understand all settings / mechanics. I‘m confused whether or not I should enable the Infuse „fetch metadata“ setting if I ONLY use it as Emby client, so Emby Server already provides all metadata.
So will this setting automatically be ignored for Emby/Plex servers? Or does infuse (if setting enabled) try to fetch metadata twice, once from Emby server, once from internet databases?
Best regards
