Infuse doesn’t load Webdav anymore
Hi since the new update I have a problem with my Webdav content. I add my Premiumizeme login and add folders as favorite but when I click the folder it doesn’t go into the map but instead goes into a loop (shows my root folder).
Problem is it doesn’t load ANY content anymore and I cannot use Infuse anymore because of it. Metadata isn’t found etc because it stays at the root folder instead of accessing movies folder
Just noticed I have the exact same issue!
