Infuse crashed when selecting Airplay
Since upgrading my Macbook Pro to the new MacOS Sonoma 14.1 - my Infuse app crashes when starting an Airplay stream to my LG TV. During connecting, the app crashes every time. This all worked before upgrading to the new MacOS.
Does anyone have an idea what I can do best?
  • I’ve restarted my Mac multiple times
  • I also re-installed the Infuse app, no luck
  • I also installed the latest Infuse update that was released today, no luck
I’m pasting a part of the crash report, if that could be helpful.
Blockquote
Translated Report (Full Report Below)
Process: Infuse [18035]
Path: /Applications/Infuse.app/Contents/MacOS/Infuse
Identifier: com.firecore.infuse
Version: 7.6.1 (7.6.4559)
App Item ID: 1136220934
App External ID: 860133075
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-10-30 12:51:09.1628 +0100
OS Version: macOS 14.1 (23B74)
Report Version: 12
Bridge OS Version: 8.1 (21P1069)
Anonymous UUID: AF9408B6-EC59-026B-9E23-76AB368FF8B1
Sleep/Wake UUID: 9AE40126-C922-4010-88D6-78FB4BC2F8FC
Time Awake Since Boot: 20000 seconds
Time Since Wake: 3629 seconds
System Integrity Protection: enabled
Crashed Thread: 16 com.apple.coremedia.sharedRootQueue.47 Dispatch queue: */CU
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Codes: 0x0000000000000001, 0x0000000000000008
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [18035]
VM Region Info: 0x8 is not in any region. Bytes before following region: 140737486614520
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
shared memory 7fffffe57000-7fffffe58000 [ 4K] r-x/r-x SM=SHM
Thread 0:: Dispatch queue: com.apple.main-thread
0 QuartzCore 0x7ff815d965e6 _CAInternAtomWithCString + 193
1 QuartzCore 0x7ff815d193ed CAInternAtom + 116
2 QuartzCore 0x7ff815d1b985 +[CALayer defaultValueForKey:] + 37
3 QuartzCore 0x7ff815d1b101 classDescription_locked(objc_class*) + 3535
4 QuartzCore 0x7ff815d1a000 classDescription(objc_class*) + 221
5 QuartzCore 0x7ff815d19b36 CA::Layer::class_state(objc_class*) + 72
6 QuartzCore 0x7ff815d199df -[CALayer init] + 99
7 MediaToolbox 0x7ff81d5571c7 0x7ff81d08e000 + 5018055
8 AVFCore 0x7ff8238c318c -[AVPlayerLayer init] + 190
9 AVFCore 0x7ff8238d1307 +[AVPlayerLayer playerLayerWithPlayer:] + 22
10 Infuse 0x105979c1e 0x105911000 + 429086
11 libdispatch.dylib 0x7ff80d5f02e6 _dispatch_call_block_and_release + 12
12 libdispatch.dylib 0x7ff80d5f159a _dispatch_client_callout + 8
13 libdispatch.dylib 0x7ff80d5fd8e1 _dispatch_main_queue_drain + 993
14 libdispatch.dylib 0x7ff80d5fd4f2 _dispatch_main_queue_callback_4CF + 31
15 CoreFoundation 0x7ff80d8b4056 CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE + 9
16 CoreFoundation 0x7ff80d8732b5 __CFRunLoopRun + 2459
17 CoreFoundation 0x7ff80d872352 CFRunLoopRunSpecific + 557
18 HIToolbox 0x7ff8181149d9 RunCurrentEventLoopInMode + 292
19 HIToolbox 0x7ff8181147e6 ReceiveNextEventCommon + 665
20 HIToolbox 0x7ff818114531 _BlockUntilNextEventMatchingListInModeWithFilter + 66
21 AppKit 0x7ff810e82885 _DPSNextEvent + 880
22 AppKit 0x7ff811776348 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
23 AppKit 0x7ff810e73dfa -[NSApplication run] + 603
24 AppKit 0x7ff810e47e10 NSApplicationMain + 816
25 AppKit 0x7ff8110fb6c8 _NSApplicationMainWithInfoDictionary + 16
26 UIKitMacHelper 0x7ff82719382b UINSApplicationMain + 1329
27 UIKitCore 0x7ff91d39443a UIApplicationMain + 144
28 Infuse 0x105d5e7c5 0x105911000 + 4511685
29 dyld 0x7ff80d4103a6 start + 1942
Blockquote
Are you able to AirPlay to your LG from other apps?
Which model LG do you have? Are there any software updates available for it?
Can you send in a report from Infuse, and post the 5 digit code here?
- Yes, both from the Macbook and my iPhone
- LG OLED48C25LB - running the latest update
  • Hm, I’m seeing this in the Mac app: No Email Account - Set up an email account in the Settings app and try again. Looks like I can’t actually set up an email account in those settings?
    By the way, I also requested support. This is the ticket ID: #157695
