Infuse 6 seems to be a little buggy with the most recent updates.
I stream all my content from Put.io over WebDav - and quite often, Infuse seems to lose connectivity. Like it’s no longer able to use the internet. If I exist infuse, and try out AppStore, works fine. If I try out any other app that uses the internet, works fine. The only thing that fixes it is if I put my Apple TV to sleep.
thanks. It seems to be less frequent, but it looks like it does still occasionally lose connectivity. I suspect that it does it when Infuse begins syncing.
I’ve submitted another diagnostic: HAZ8J
I’d like to point out that I was able to submit this, and several other diagnostics even though it was failing to play my cloud content. I didn’t have to reboot Apple TV. In some cases, it doesn’t play on an immediate attempt, and if I wait several minutes it plays, and sometimes it works immediately when replaying.
Also, this is with Infuse 6.5.3, but TV OS 14.0 - for some reason my Apple TV did not update automatically even though it was set to do so.
I’ve manually updated to 14.2 now, and will report back soon.
