Infuse cache not delete
from what i’m reading infuse is supposed to clear the cache when you quit the app, but even tho i quit, reopened, quit again, and restarted my computer several times, the cache is still here and takes a lot of space, and I can’t figure out why, it’s super annoying
as an asides, can I delete it manuallY ?
This is a temporary cache that the system will clear out. It may not happen immediately, but it will not stay long.
If you want to avoid this disk cache you can adjust the ‘Streaming Cache’ option found in Infuse > Settings > Playback.
gotcha. in my case it stayed for over a day which has been annoying
