Infuse Audio
Same on iPhone 4 with 6.1.3, I have also checked the second episode too with the same problem.
your completely right this app is quality & i do want to use it, they have had more time to get everything ironed out. how can i cut a sample of it out using a Mac? how long do you need it to be? I can upload to dropbox for James to grab.
Any length should be fine, in fact if you want to just upload the whole thing to Dropbox and PM me the link that would work.
Seems the bug I had on my upload I sent you has disappeared with v1.3!!! Whooooooo… Good work guys :slight_smile:
Great! Thanks for following up. :slight_smile:
