Infuse as a Plex Client
Using infuse as a plex client has been added to the suggestions area of the community page (link below). If you really do want this follow the link to the community section and vote for this suggestion to help get it added to a future update.
Link on community site : https://support.firecore.com/hc/en-us/community/posts/114096510733-Infuse-as-a-Client-of-Plex-and-Plex-Media-Server
Cheers
Yes, totally agree with this idea
It is the main feature infuse is lacking.
hurtauda
Are there any news, whether this will be included it the new version and when this will the available? Looking forward to using that feature!
@James, can you report anything new on this? Thanks.
I would like to know this too, please!
Yes, please :slight_smile:
Anything?
I should imagine infuse 6.0 is coming up in a couple of months, I’d be willing to pay extra if you implement this feature.
I would also really like this feature (mainly for Plex Cloud). Both MrMC and the Squire app supports Plex Cloud. Would be really nice if Infuse taking up for this competition.
Add another name to this - I’m looking to replace the plex client on my AppleTV and would love to use Infuse for it.
Would be much appreciated if we could get an update on whether this is even being considered? Thanks.
Very good idea ! No news ?
You’re probably get a faster response via twitter, the last time I asked they said they were looking into it.
Count me as someone interested in this!
Count me in please!
Making Infuse the Plex client Plex Media Player for Apple TV should have been is a great propsal. I can‘t agree more.
Infuse‘s metadata handling is rather incomplete, on the other hand it‘s playback capabilities are far better than the ones of Plex Media Player for Apple TV.
To be honest, I don‘t like those automated metadata fetching functions whether it is Plex or Infuse. Those functions only work 90% of the time and produce more problems and work in the long run for large movie collections than what they should avoid.
My regular process when transferring a newly bought bluray to my server is to also encode two m4v-versions of the mkv-rip at different resolutions and quality levels and embed metadata and bluray cover with Subler for macOS. If you set the metadata correctly you can easily handle multiple versions of the same movie (tag contentID), control display order for collections (tag SortName), etc. Storing three versions of a movie guarantees they all run well on all sort of devices: from high quality on the large screen to watchable on your phone.
The two m4v-files are fully iTunes- and Plex-compatible. iTunes for example can read a directory structure with 1000+ movies in just a minute or so. macOS and Windows will also display the movie cover in Finder or Explorer which is nice and when you move a file, all metadata will move as well.
Unfortunately I didn‘t find a way yet to embed the same metadata in the mkv-file. There is no tool for macOS afaik. Fortunately when using Plex, Plex simply takes the embedded metadata from the m4v-files and uses them for the mkv-file as well, as long as all three files are in the same single directory.
So, after setting up all movie and tv-show files on the server with proper metadata, Infuse would be the best Apple TV client to display and playback a movie collection, if it could connect to a Plex server.
Does pending in front of the thread now mean it is being worked on?
I hope so !
I really hope Infuse and Plex can work together and produce magic. I would be willing to pay extra for it too!
+1 for me too. Hopefully handle it better than MrMC though as that’s a sloppy integration (not sure if Plex’s fault or MrMC)…
I agree. Mrmc is ok but it’s not as smooth as Kodi.
