Infuse and Plex
Dear,
I’m looking for a solution that reduces the latency when I’m accessing my Plex data remotely via infuse. If I compare the accessibility of this data in Plex or the infuse app, there is an huge difference btw the 2. Any idea how to solve this ?
Regards,
Jan
Are you seeing trouble with browsing videos, or actually playing them?
Once Infuse has finished initially caching info about the videos in your library, you can browse using Infuse’s library which won’t require any connection to the Plex server. A connection would be made only if you choose to play something.
Does the iCloudSync also sync the Plex-Sharing-Settings between tvOS and iOS?
You will need to login to Plex on each device, but things like Library categories and artwork will sync via iCloud.
