Trying to find a way to connect Infuse directly to my Drobo for media. I can use the Plex DLNA server for this but can’t seem to connect directly to the Drobo shares.
Anyone had success with this?
How do you connect to your Drobo shares from your Mac or PC? (I suppose you have network attached Drobos, otherwise if they are attached directly to a computer, it’s just about connecting to the computer)
The same way will probably also work with Infuse, which supports NFS, SMB, and probably several more.
You probably have a Drobo software to configure it.
In my opinion the simplest thing is to use NFS with read-only access to your media folders without any IP address restriction on your local network (NFS access rights are by IP address, not by user).
