Infuse 8 Bug with Seeking AppleTV
There is a bug with Infuse 8 on Apple TV. When you start infuse and watch a tv show you are apple to press forward on the remote to skip forward 10 seconds. You are able to press forward multiple times in a row to rapidly skip forward.
This works fine for a bit, but if you watch an episode or 2 in a row, eventually you can no longe rapidly skip forward multiple times. You can only press forward on the remote once, it will skip 10 seconds, but you can’t press it again until after the onscreen controls disappear.
Closing infuse completely and restarting it fixes the issue for a little bit but then it starts again.
this is the same issue
see this thread
“Skipping forward does not work while endless watching”
