Infuse 8.4.8. Sync Problems with Trakt.tv pro version
Hello together,
First I am a big Fan from infuse really love it works on all my devices (Apple TV, iPhone, iPad, Mac Mini, MacBook) .
But a week ago I saw some unwatched movies in my Gallery and thought what happened? Why? Then I saw that the Apple TV was not connected to Trakt, so must be automated disconnect. After reconnect all fine the Movies are again marked as watched. Then one day later the same on my mac, reconnect to Trakt and then a lot of movies were unwatched. Checked the Status on Trakt and there was everything fine all Movies are as watched marked.
After testing a lot via Chat gpt, i decided wrong and delete infuse on all devices and Build it new, because I thought should be no Problem all watched status are right on Trakt. But After the rebuild of my collection only the movies which I saw the last 3-6 month are marked as watched and all tv series are unwatched :see_no_evil_monkey: only the actual episodes are tracked right from the watching (first row) but all other episodes from the seasons are unwatched.
all I watched via infuse is immediately imported to Trak.tv so this way works fine but it seems that Trakt don‘t send the watched status back from older entries :weary_face: any idea? All other things, iCloud Sync between the devices is working. I have a really huge Collection before I spend a whole day to do it manually I want to ask you if you have an idea what to try next?
Thanks in advance :blush:
Best regards
A post was merged into an existing topic: tvOS: Library wiped to unwatched overnight, Trakt history failing to pull down
