Infuse 7 : Missing Watching section at the top of the interface
I don’t know if I’m missing something simple but I don’t have the Watching section at the top of the interface (iPad and AppleTV). Cf the image found on the Firecore’s website. This section is present in my Infuse 6. Thanks
home-hero-infuse7_4x
You may check to ensure the ‘Up Next List’ option is enabled in Infuse > Settings.
With this on, the top row will consist of a Watching section as well as Recently Added section. Of course, if Watching is empty then this section will be hidden.
As a quick test, you can try adding a title to Watching manually. Just long-press on an item, select Playlists, and then check Watching.
Works!!!
Thanks @james for your quick help!
