Infuse 7 - Actors etc
Hi @james,
I like the new design of infuse 7.
I have just noticed, that there are even „icons“ of the producers, actors etc. at the bottom of the Movie. Is it correct, that there are not real pictures of the persons, but instead just an icon?
Btw I already recreated all meta data.
This is expected for now.
However, actor artwork will be added once we complete the transition to TMDb for TV shows.
Thank you for the answer.
Can you tell, when do you plan this Transition?
It’s currently on the list for 7.1.
