Ahnl
March 18, 2023, 7:52am
1
When I play a Dolby Vision file created by iPhone 13 on my LG Oled C9, the TV shows the HDR logo rather than the DV logo. Tried all DV options in settings. It used to work in the previous version. Is this a bug, by design, or did I do something wrong?
Anyone any idea? Thanks!
Could you run the video through mediainfo and post the results here?
What device are you using to play on the LG? ATV, iPhone? What OS version?
Ahnl
March 19, 2023, 3:55pm
3
Thanks - it is on an AppleTV 4K, latest TvOs (16.3.3).
Algemeen
Volledige naam : IMG_4810.MOV
Formaat : MPEG-4
Formaatprofiel : QuickTime
Codec-ID : qt 0000.00 (qt )
Bestandsgrootte : 82,5 MiB
Duur : 12s 753 ms
Totale bitratemodus : Variabel
Totale bitrate : 54,2 Mb/s
Datum codering : UTC 2023-03-17 20:44:16
Tagdatum : UTC 2023-03-17 20:44:16
Gebruikte encoderbibliotheek : Apple QuickTime
com.apple.quicktime.location.accuracy.ho : 50.000000
com.apple.quicktime.make : Apple
com.apple.quicktime.model : iPhone 13 Pro
com.apple.quicktime.software : 16.3.1
com.apple.quicktime.creationdate : 2023-03-10T15:58:47+0100
Video
Formaat : HEVC
Formaat/Info : High Efficiency Video Coding
Formaatprofiel : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.10, BL+RPU, HLG compatible
Codec-ID : hvc1
Codec-ID/Info : High Efficiency Video Coding
Duur : 12s 753 ms
Bitrate : 54,1 Mb/s
Breedte : 3 840 pixels
Hoogte : 2 160 pixels
Beeldverhouding : 16:9
Rotation : 180°
Frameratemodus : Variabel
Framerate : 60,000 FPS
Minimale framrate : 54,545 FPS
Maximale framrate : 60,000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.109
Stroomgrootte : 82,2 MiB (100%)
Titel : Core Media Video
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
Matrix coefficients : BT.2020 non-constant
Metas : 3,4
Codec configuration box : hvcC+dvvC
Audio
Formaat : AAC LC
Formaat/Info : Advanced Audio Codec Low Complexity
Codec-ID : mp4a-40-2
Duur : 12s 753 ms
Source duration : 12s 817 ms
Bitrate-modus : Variabel
Bitrate : 171 kb/s
Kanaal(en) : 2 kanalen
Channel layout : L R
Samplerate : 44,1 kHz
Framerate : 43,066 FPS (1024 SPF)
Compression mode : Lossy
Stroomgrootte : 266 KiB (0%)
Source stream size : 267 KiB (0%)
Titel : Core Media Audio
james
March 20, 2023, 9:38pm
4
Would you be able to upload a sample video you are seeing issue with?
https://upload.firecore.com
Ahnl
March 20, 2023, 10:08pm
5
Done: Ahnl - IMG_4810.MOV
james
March 21, 2023, 7:28pm
6
Thanks for the sample. Looking into one potential issue here.
Can you confirm which Apple TV 4K model you have (1st, 2nd, or 3rd gen)?
Also, are both Match Content options enabled?
Ahnl
March 21, 2023, 7:43pm
7
It’s 2nd gen 4K. Both are enabled.
