Infuse 7.1 Genre
Unfortunately, local metadata still does not work. can you finally fix the problem? In the case of films, it has worked for years without any problems.
Can you elaborate on what you are seeing?
I don’t think we’re aware of any issues in this area.
I had mentioned that before and hoped that it would work in the meantime. here is the link
