Infuse 6 question
Does it still get updates or will it sooner or later cease to function ?
James has announced that Infuse 6 is due one more update to handle the transition from thetvdb.com to the themoviedb.org for TV metadata.
thetvdb.com are planning on discontinuing the current version of the ABI used by Infuse which is why this is required.
As @remotevisitor said, there will probably be one final update to V6 to handle the change from TVDB to TMDB for TV shows do to an API change at TVDB.
Here’s a post where this is addressed by James.
Where James says this will most likely be the last update for V6
