Infuse 6 Pro + Synology UPnP => empty Library
Hi team,
I have some grown collection of anime series and movies on my Synology.
These files are shared by using “Media Server” + “Video Station” with activated UPnP service.
Inside the Infuse 6 Pro (iOS + tvOS) I can add and access Synology’s shared folders without any problems.
But the Setting/Library in Infuse 6 Pro stays empty showing 0 films, 0 tv-shows and 0 other items.
I think therefore the first tab (iOS iPad version) also is gray-out is deactivated.
What do I wrong? How to fix this problem?
On AppleTV 4K the same situation, the Library shows 0 items.
Kind regards,
Anton
I believe you’ll need to use a different connection like SMB to use the library feature. I don’t think that “Library” and UPnP play well together.
