I found an other bug on my 30 euro dissapointment that’s called Infuse 6. Sorry, there is no other way to call it
I noticed that tv show episode files that contain 2 episodes in one (s04e01e02) are not both visible in the interface. That’s just episode 1 and then 3 visible.
james
March 18, 2020, 1:29pm
2
Support for double episodes is not currently available in Infuse, but is something which may be added in the future.
There is a thread in the suggestions area where this can be discussed.
Hello
I’ve ran into a issue with infuse not recognizing multi-episode in one file. Is this setting not available ?
I used xbmc (kodi) and it’s fairly easy how they set it up.
From xbmc (kodi) wiki page :
In cases where your file contains more than one episode, you can specify all the episodes included. Everything after the first found pattern match will be checked for further matches to the same pattern.
Examples :
anything_s01e01_s01e02.ext
anything.s01e01.episode1.title.s01e02.episode2.…
system
Closed
May 14, 2020, 4:47pm
3
