Option to delete files is not available anymore with file management turned on in Infuse 6 when connected via WebDAV. (And yes, I am logged in to a user account that has full edit/admin permissions on the folders). This wasn’t an issue before in Infuse 5.x
Any thoughts? Starting to wonder why I paid for a lifetime upgrade to lose functionality.
Works in SMB but not in WebDAV. Works in nPlayer with WebDAV but not in infuse 6.
If you have not done so already then I suggest you raise a support ticket? I suspect it is more likely to be a bug than anything deliberately removed.
This has been added, and will be available in the upcoming 6.0.4 release. ![]()
