Infuse 6.7 and DSM 7.1.1
Hello ,
Since updating my NAS to version 7.1.1
Infuse 6.1 installed on my Apple TV4K no longer works.
The thumbnails appear but cannot access the library. Only a circular icon appears on the screen.
have you noticed anything similar?
Can you try updating to latest version of infuse 7 and see if it works?
I also use a Synology NAS with DSM 7.1.1 + infuse 7.4.6. Everything works fine.
I checked on Infuse 6.7 - everything works.
5 posts were split to a new topic: Problem connecting via UPnP With Infuse 7.4.6
Not sure if you got a reply to them but sometimes after a DSM update you may need to go in and enable the file service again
