Pressing the Apple TV remote control to do the standard 10 second skip doesn’t work. What happens instead is Infuse 6 skips forward odd amounts. It seems as if the skip forward is a percentage of how much time is left in the file. For example, an hour long TV episode skips forward 4 mins, whereas a 30 min TV episode skips forward 2 mins. Near the end of the file, it doesn’t skip forward at all.
Infuse includes 2 options for ‘edge taps’. The default is 10s forward/back, but you can switch to chapter skip by enabling the Chapter Controls option in Settings.
Turning off Chapter Controls will allow you to use the normal 10s skip.
Thanks!
