The new version now suffers from the same issues as the tvOS version, whereas the 6.1.5 played all files smoothly on iOS 13.
4K HDR files suffer the most, where playback is basically unusable.
But 1080p SDR files do not play smoothly either. It’s as if either the frame rate is low or there is some issue with the sync.
The app is pretty much unusable on iPhone right now.
I can’t get 4K files to play on Plex on the iPhone (they play on Apple TV), but 1080p files play smoother than Infuse. But that’s beside the point. Infuse 6.1.5 played all files smoothly.
