Infuse 5 Problems with iXpand Drive
I bought the iXpand Flash Drive and wanted to use it with infuse. It recognizes without any Problems and shows the stick in Infuse. I can open it and it shows me my Folders.
But when I want to select f.e. the movies Folder, it often doesn’t jump into the Movies but shows the main Folder Structure again. I can click again and it shows again.
Now I can go all the selects back until I see the Drive in the List an reselect it. Now, with al little bit of Luck I can select the Movies Folder and see my Movies. But normally this procedure goes on and on until I can see the right contents.
What is the Problem? It is ExFat formatted. Does anyone have some Tips?
What capacity?
64 gb
