hi all,
i have a lot of movies in a shared folder called MOVIES on my synology.
Every movies.mkv are stored in separated folder with nfo file and poster.jpg
i set to use incorporated metadata and download metadata but some movies are not reconized
example: superman 1 (1978) and RED (2010) are inverted. if i select superman i see red and if i select red i see superman.
this happens for several movies
i check nfo and they are correct , and also the file metadata.
