For about a week or two I have a problem metadata for my movies couldn’t be found and got.
What’s the problem?
Strictly a guess but with the sources for metadata (TMDB & TVDB) both updating their APIs for fetching info I’d guess that the API in Infuse 5 is at the end of life cycle and won’t be supported by the sources any longer.
The other possibility is the country you’re in may have put blocking in place for those sites.
You may also check to see if one of the folders has been tagged as local metadata.
If this happens, you’ll need to untag the folder and clear all metadata in order to refresh.
More info on using local metadata can be found near the end of this guide.
