Infuse 5 issue
Just grabbed infuse 5 off the store but when I open it after installing it just goes back to the home screen (i.e. Doesn’t open). Reinstalling does not fix issue and running tvOS 10.0.1
This issue also happens on my 2nd ATV4, running tvOS 10.1 beta 3.
Did you make a clean install (removes version 4 first and then install version 5) or did you just upgrade ?
Removed version 4. I still have the beta installed
Update: Removing the beta also, fixes the issue
I found that although my Purchased apps only showed inFuse 5 if I used the App Store search feature I could still find v4 and install that (after I encountered the issues with v5), and subsequently restore the inApp purchase to the Pro version. At the moment I therefore have both v5 installed without the Pro upgrade and v4 installed with it.
