Infuse 5 - Dolby/DTS Passthrough
Hi there,
Do we always have to do all the settings in Infuse 5 and in the ATV4 as for the v4, or everything is ok now and we can leave everything “by default” (meaning that I will have the Dolby back for Netflix as for now it’s on PCM on my amplifier because of those v4 settings ) ?
Thanks.
Do it in the Infuse settings, you can choose auto or passtrough. OR in the movie that your are watching scrolling down chose audio, and select passthrough and then roll back to auto if you want.
The settings INTO Infuse app only applied to Infuse APP , not with the general settings of your ATV.
  • The settings in your ATV needs set to “Best quality available”
