Infuse 5 and audio language
Hi all. With my Infuse Pro 4 I can change audio language as I prefer during playback of movies. With Infuse 5 the movie is played with the main language and if I try to change, Infuse ask to me to upgrade to PRO. Is it normal ? Thank in advance
Some video (and audio) types require Pro, so it sounds like you may be selecting an audio track format that is available only when using Infuse Pro.
You can get a free month long trial of Infuse Pro by selecting the yearly subscription option that appears on the purchase prompt. This will allow you to try all the Pro features without being charged.
