Hello,
Infuse pro no longer works on my SMB share.
I can’t see my Library. The movies data are very very slow to charge. But I try on the free Infuse and there it works perfectly.
Can you help me ?
Are you running two copies of Infuse on the same ATV at the same time? What do you mean by “free” version?
The bug is present even if a version is launched. There is the pro version and the free version
You may want to delete one and start again with only one copy of infuse on your ATV.
I reinstalled Infuse Pro and it works. but I lost the information If I saw the movies or not ?
Thank for your help
Glad you’re back on track!
