Infuse 4 - forgotten pin
Hi
I haven’t used Infuse 4 for awhile and I went use it tonight and realised I can’t remember my pin. Is there any way that I can reset it to gain access at all please.
Thankyou
Martin
You won’t be able to reset the password, but removing and reinstalling the app will allow you to start using it again.
If you have videos in the app you’d like to recover, you can use iTunes File Sharing to transfer them to a Mac/PC.
