I’m also trying to get this to work. I’ve opened the port for SMB (445) in my router and pointed the adress in the app to my Synology NAS but it won’t connect. Has anyone gotten this to work with a Synology?
I’ve gotten this to work. I gave up trying to get it work using SMB and instead I turned on WebDAV on my Synology. I then manually added the NAS to Infuse using WebDAV as the protocol. This way it works great. So you guys could also try that.
