Infuse 2, AnimeFan problems
it seems infuse 2 cant play any of my anime fansub collection… i heard something of a 10bit thing…, the files are not hi-res… only 720p…
will there be support down the line for this type of encoding?
this is the spec of the file:
Format                         : Matroska
Format version                 : Version 2
File size                      : 457 MiB
Duration                       : 23mn 40s
Overall bit rate               : 2 701 Kbps
Movie name                     : Nagi no Asukara - 03 - The Tradition of the Sea
Encoded date                   : UTC 2013-10-18 03:45:15
Writing application            : mkvmerge v4.4.0 (‘Die Wiederkehr’) built on Oct 31 2010 21:52:48
Writing library                : libebml v1.0.0 + libmatroska v1.0.0
TITLE                          : No OP / ED
Attachment                     : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High 10@L5.0
Format settings, CABAC         : Yes
Format settings, ReFrames      : 16 frames
Muxing mode                    : Header stripping
Codec ID                       : V_MPEG4/ISO/AVC
Width                          : 1 280 pixels
Height                         : 720 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Variable
Original frame rate            : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 10 bits
Scan type                      : Progressive
Title                          : H.264 (10-bit)
Writing library                : x264 core 138 r2359+704+48 3f879a0 tMod [10-bit@all X86_64]
Encoding settings              : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.80 / psy_rd=0.50:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=14.1000 / qcomp=0.75 / qpmin=0:0:0 / qpmax=81:81:81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.65 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Default                        : Yes
Forced                         : No
Matrix coefficients            : BT.709
Audio
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Codec ID                       : A_AAC
Duration                       : 23mn 40s
Channel count                  : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 44.1 KHz
Compression mode               : Lossy
Title                          : Japanese 2.0 AAC
Language                       : Japanese
Default                        : Yes
Forced                         : Yes
Text #1
Format                         : ASS
Codec ID                       : S_TEXT/ASS
Codec ID/Info                  : Advanced Sub Station Alpha
Compression mode               : Lossless
Title                          : English subtitles (without honorifics)
Language                       : English
Default                        : Yes
Forced                         : No
Text #2
Format                         : ASS
Title                          : English subtitles (with honorifics)
Language                       : enm
Default                        : No
Forced                         : No
Menu #1
00:00:00.000                   : en:Intro
00:00:40.122                   : en:Opening
00:02:10.087                   : en:Part A
00:11:37.070                   : en:Part B
00:22:00.151                   : en:Ending
00:23:30.116                   : en:Next episode preview
Menu #2
Improvements for 10bit playback will be included in the upcoming 2.2 update.
i upgraded to infuse 3 pro… playback for 10bit mkv is still choppy and has artifacts?
