Infuse 101 Question: 4k HDR choking ATV4K + Infuse
File: mkv of Deepwater Horizon 4k
Server: Synology DS218+
AVR: Yamaha 2070
Cables: All premium certified
Players: ATV4K + Infuse vs.
Oppo 205
Network: 1GB wired to ATV and Oppo
Result: Oppo plays file fine. InFuse + ATV buffers every minute or two.
Is there a setting for encoding - or within the ATV/Infuse that will help?
Thx.
One quick thing you can try is switching to SMB2 to see if this helps.
This will avoid issues with any encryption settings you may have enabled on your Synology, which can result in slower transfer speeds.
