Indexing Failed for Jellyfin
I have Jellyfin running on a local server. Infuse is able to connect to it and play anything.
However when it is in Library mode not a single one of my devices will sync successfully. Everything comes back with “Indexing Failed”. I’ve tried this on AppleTV, iPhone, and iPad. Each device receives the same error.
Jellyfin 12.1
Infuse 8.5.5 (5752)
InfuseSync 1.5.3.0
Diagnostics code: 6DB3V
It looks like Infuse cannot connect to the Jellyfin server as entered.
Can you check to ensure the server address is correct and it’s online?
Yes the server is online and I am able to connect. I can open the share and play any video file, I am also able to conduct successful speed tests to the server.
I just updated the Infuse app to 8.5.6 (5763) and have been unable to conduct a successful sync. With the new version I created a new diagnostic code: EFWHP.
No sure if it will help, but most index fails on Jellyfin are due to out of date infuse plugin app or the app is not active,if you look under Jellyfin apps, it will say active or inactive under infuse plugin, if it’s inactive, try restarting Jellyfin in the the app there’s an option to do this in dashboard, this should make infuse plugin active, simply closing Jellyfin doesn’t always work.
