At random times, Infuse starts failing to fetch new content from a Jellyfin server, saying “Indexing Failed for Jellyfin”. It started happening after updating Jellyfin to 10.8.9. Refreshing and clearing metadata result in the same thing.
I’ve yet to find a workaround, except for removing the server in Infuse and signing back in. Unfortunately, the problem comes back later.
At the time of writing, indexing is failing on iOS and tvOS, but not on the macOS client (currently). The fact that new content is being indexed on macOS leads me to believe that this issue is on Infuse/Infuse Sync’s side
It keeps saying “No Email Account” when I try to send it. I went to settings but couldn’t find where to add an email other than the icloud settings. Where is it?
You can add an email account in the iOS > Settings > Mail > Accounts area. Unfortunately, using the native iOS Mail app is the only way to submit logs at this time from Infuse for iOS.
It’s possible you may need to check the network settings for Docker. These can be different than a standard install, and if you are using multiple installations on the same device one may override the other.
Sorry I should have stated that the problem occurred “out of the blue” (sorry I just don’t know what broke it, as I have some auto-updates).
And I installed the Linuxserver version of the docker today, before that I only had the official one. So that’s not the problem
