When I watch 4K .mkv media using Infuse, the subtitles are often in the wrong place. The attached image shows placement in Prometheus, using the default vertical alignment setting. By comparison, VLC and Kodi position them correctly.
My setup:
Apple TV 4K
tvOS 11.0 (15J381)
Infuse Pro 5.5.4
james
October 6, 2017, 10:24pm
2
Do you know what type of subtitles these are?
Are they embedded or external?
james
October 6, 2017, 10:29pm
4
If you have a chance, would you mind running one of the files through MediaInfo and attaching the specs?
MediaInfo is a free download available at the links below.
Mac
http://fireco.re/YCm3
PC
http://fireco.re/YCY2
No problem – please see attached.
prometheus-mediainfo.txt (9.07 KB)
james
October 6, 2017, 10:34pm
6
Thanks! We’ll take a look and see if we can get this fixed up.
Thank you! I really appreciate the prompt response. Infuse is awesome.
This happens to all remuxes i do with makemkv or mkvtoolnix.
james
October 12, 2017, 6:45pm
9
We have replicated this issue here and are looking into a fix.
james
November 2, 2017, 4:21pm
10
FYI, we have resolved this for the upcoming 5.6 update.
JesperS
November 2, 2017, 7:20pm
11
Very nice. When will 5.6 be released?
JesperS
November 2, 2017, 11:04pm
15
Then we are just waiting on Apple to enable Dolby Atmos in tvOS11
system
Closed
May 26, 2020, 8:33pm
16
