Episodes in season 2 of Re:Zero is not showing the correct metadata despite the first season working just fine. I’ve tried:
Refreshing library metadata
Manually editing metadata to the correct series
Switched the metadata to a different series then switching back
Cross checked on TMDB
I’ve attached the screenshots for season 1 and 2 of the series on Infuse. I also have the screenshot for the naming convention that I use.
I’m using Infuse 8.5.9 with SMB connection from my computer to iPhone.
s29
November 3, 2026, 2:30pm
2
Re:Zero is not exist season 2 on TMDB
Re: Zero doesn’t show anything past season 1.
Natsuki Subaru, an ordinary high school student, is on his way home from the convenience store when he finds himself transported to another world. As he's lost and confused in a new world where he doesn't even know left from right, the only person...
It looks like there are currently 85 episodes in season one and you show it in your directory as only 25 so maybe try changing the name of your season 2 episode 1 to being S01E26 and see if that gives you the correct metadata.
